12-30-2019 04:39 PM - edited 12-30-2019 04:40 PM
Is there a way to check the antenna model name of the AP?
Solved! Go to Solution.
12-31-2019 07:05 AM
12-31-2019 07:05 AM
01-03-2020 01:12 AM
wrong forum but ...
Cisco APs that accept external antennas don’t know what you’ve connected to them. They are not smart antennas. You can get a list of supported antennas from the AP’s data sheet. And you need a visual inspection to check what’s connected. And don’t forget to set correct the antenna gain in the AP config !
