08-10-2018 11:12 AM
Inside authorization profile in the common tasks area with Security Group checked, then selecting a security group tag, a field for 'Virtual Network' appears. Where do we create this virtual network from?
Jennifer
Solved! Go to Solution.
08-10-2018 01:00 PM
I am pretty sure that is all part of SDA/DNA-C/ISE integration, but I could be wrong on that.
08-10-2018 01:00 PM
10-30-2018 03:10 AM
Did you get a resolution to this. I have this same issue and cannot specify a VN in my auth profile.
regards
Ian
10-30-2018 08:51 AM
As paul said, this depends on DNA-C. I believe it supported in SD-Access in DNA-C 1.2.5+.
During Provisioning the fabric, we add VN with a IP pool and there we may select a Scalable Group (under Groups) with the VLAN (under Auth Policy).
