Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
330
How to create virtual network in authorization profile when security group is checked
Inside authorization profile in the common tasks area with Security Group checked, then selecting a security group tag, a field for 'Virtual Network' appears. Where do we create this virtual network from?
Jennifer
1 ACCEPTED SOLUTION
VIP Engager
Re: How to create virtual network in authorization profile when security group is checked
I am pretty sure that is all part of SDA/DNA-C/ISE integration, but I could be wrong on that.
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Campus/CVD-Software-Defined-Access-Design-Guide-2018APR.pdf
3 REPLIES 3
VIP Engager
Beginner
Did you get a resolution to this. I have this same issue and cannot specify a VN in my auth profile.
regards
Ian
Highlighted
As paul said, this depends on DNA-C. I believe it supported in SD-Access in DNA-C 1.2.5+.
During Provisioning the fabric, we add VN with a IP pool and there we may select a Scalable Group (under Groups) with the VLAN (under Auth Policy).
