IBNS 2.0 RADIUS send switchport access vlan
mstraessle
Level 4
Level 4
I am looking for a solution for the following requirement:
In IBNS 2.0 I need to get the informations about the configured "swicthport access vlan" from the requesting switch.
Since the switch itself knows the static configured vlan from the port-configuration, it should be possible to integrate this into the MAB Call-Check in the same way as I have the SSID in the WLAN RADIUS request's in the calling-station ID.
But either the "feature" is not supported, or I am very bad in google-ing and reading RFC's that I missed the correct hint.
You probably ask: Why the hell we need this? The use-case is simple: different OU or companies are using MAB on different directories. And instead of a authentication sequence for 10 or more OU's, I would like to dispatch the MAB lookup to the correct directory when arrive on ISE using external RADIUS Servers.
Any idea how to instruct IOS 15.x to do so? I tried all possible commands using "radius-server attribute xxx", but was not successful so far.
Thanks, Marco
howon
Yes, it should work as long as you are running 15.2(2)E/3.6.0E/15.2(1)SY and higher and with following commands. The VLAN ID & VLAN Name are carried in Tunnel-Private-Group attribute. Following is the configuration you need to add it to the AuthC request:
switch(config)#access-session attributes filter-list list custom-name
switch(config-com-filter-list)#vlan-id
switch(config-com-filter-list)#exit
switch(config)#
switch(config)#access-session authentication attributes filter-spec include list custom-name
FYI, you can also do the same for the older IOS (12.2(53)SE2), but works only with MAB request and the VLAN ID is carried in NAS ID field.
switch(config)#mab request format attribute 32 vlan access-vlan
howon
switch(config)#
It seams that the command above "access-session attributes filter-list list custom-name" is not available in IOS 15.2-2.E5 on my 2960S-48...
I mean: I have been gine through:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_8021x/configuration/15-e/sec-usr-8021x-15-e-book/sec-vlan-dot1x-auth-request.pdf
And thesre are my options:
switch(config)#access-session ?
  accounting             Set the attribute providers accounting information
  acl                    Application of ACLs on access-session
  cache                  Set cache configuration
  interface-template     Set the interface-template sticky globally
  mac-move               Set required action when a MAC move is detected
  monitor                Apply template to monitor access sessions on the port
  passthru-access-group  IP access-list map to FQDN ACL
  tunnel vlan            Set Tunnel Vlan Id
  vlan-assignment        set the partial vlan attrib setting globally
switch#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.2(2)E5, RELEASE SOFTWARE (fc2)
Can you explain what are the prerequisites for it? It is also referenced in BRK-SEC2691 (2015) Slide 58, but not accepted by IOS...
I am running IBNS 2.0 in new-style mode. Whatever, "mab request format attribute 32 vlan access-vlan" does fullfill my requerements so far...
I found the answer to my question, which is quite simple:
"It is not supported on C2960S" but it is nowhere written, but between the lines ther is a Statement like this:
IOS 15.2(3)E: The following commands were introduced or modified:  "access-session attributes filter-list list"
But there is no IOS 15.2(3)E for my type of Switch, which makes it simple to answer.
BTW: Feature Navigator is crappy: If I choose the corresponding Feature: "VLAN RADIUS Attributes in Access Requests" I get the following Output:
"The feature combination you searched on is not in any supported Cisco software releases in this tool. Please change the feature combination and search again."
Seams to be a typical Cisco Software...
