ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
1909
Highlighted
Beginner
Installing Cisco ISE 2.4 on Azure
Is it possible to install Cisco ISE 2.4 on Microsoft Azure? If so, could someone please provide instructions on how to achieve this? Is Cisco ISE 2.4 supported on Microsoft Azure yet?
1 ACCEPTED SOLUTION
VIP Engager
Re: Installing Cisco ISE 2.4 on Azure
I don't have any good news for you right now in regards to Azure. You could certainly run ISE in AWS with vmware cloud since they give you esxi on bare metal. At this point I would not run ISE on nested hyperv. You would have to NAT / port forward on the host hyperv server, ISE would not be given a directly accessible Azure IP. You can assigned a nested VM a static IP, but it's internal to the nested hyperv switch, thus the need for host nat rules.
4 REPLIES 4
VIP Advisor
There's no official support for Azure and AWS as far as I know.
However, if both can run VMs on a supported hypervisor, it will work.
Here the link for supported hypervisors:
https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/install_guide/b_ise_InstallationGuide23/b_ise_InstallationGuide23_chapter_01.html#hypervrequirements
As you can see ESX, Hyper-V and KVM are supported. I've never personally installed ISE on Hyper-V but the other 2 work like a charm.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
VIP Engager
I actually just posted a question on running ISE in the cloud a few weeks ago, wondering if anyone had tried it.
https://community.cisco.com/t5/identity-services-engine-ise/ise-in-the-cloud/td-p/3703425
As Francesco indicated, hyper-v  is a supported platform for ISE, and Azure does allow nested virtualization in some compute models.
I think it will work, but I'm not sure if anyone has really tried it yet. What I did find is that you will have to create static NAT rules on the azure host VM, this might be the complicated part. If you try it, I'd love to hear some feedback on how it went.
Beginner
Were you able to find more info on this ?
VIP Engager
