ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
756
Interface templates and Service Templates in IBNS 2.0 on 2960-X?
I am looking for information on how service templates and interface templates can (or not?) be used as part an ISE policy and interdependences that may need to be considered.
The INSB2.0 I have been reading through is here:
https://www.cisco.com/c/en/us/products/ios-nx-os-software/identity-based-networking-services/white-paper-listing.html
and some IOS info here
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ibns/configuration/15-e/ibns-15-e-book/ibns-coa-supp.html
There is mention of using interface templates and that we can reference them as VSA in policy but not much more.
I am also keen to get clarity on the support of IBNS 2.0 for the 2960-X platform.
I see the 2960-X as supported for most of the features – accept COA – yet it is not on the platform support matrix
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/identity-based-networking-services/whitepaper_C11-729965.html#_Toc404649500
but other less capable switches like the 2960-S are in the platform.
Any help would be much appreciated
1 ACCEPTED SOLUTION
Re: Interface templates and Service Templates in IBNS 2.0 on 2960-X?
Yes, 2960X does support IBNS 2.0. We don't have an updated list of 2K platforms that support this today, you may need to contact the switching team.
We can use Interface templates as part of ISE authorization to change specific configurations on the switch port. We have been talking about it for changes from access mode to trunk for the purpose of downstream Wireless Flex APs / Compact switches and also to apply QoS policies.
Also, the primary use case for interface-template is to contain lengthy port configurations within a container and then to source it under physical ports.
Service template are more useful locally on the switch to handle failure scenarios. ISE can authorize sessions with service-templates too, which is nothing but a set of authorization attributes (VLAN, ACL, SGT, etc) under a common profile name.
~Hari
1 REPLY 1
~Hari
