Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
85
Beginner
Is anyone running ISE 2.3 patch 7?
Is anyone running ISE 2.3 patch 7?  Are you having any issues on this version & patch?
We are currently on ISE 2.3.0.298 patch 6 and are hitting this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj02644
Cisco recommends upgrading to Patch 7.  I wanted to get other people’s feedback on patch 7.  I’d hate having to roll back in case we hit even worse bug.
thanks
T
1 ACCEPTED SOLUTION
Re: Is anyone running ISE 2.3 patch 7?
Not a direct answer, but I suggest moving to either 2.4 or 2.6 soon. We announced EoL for 2.3:
https://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/bulletin-c25-741734.html
2 REPLIES 2
While best for you to upgrade it to 2.4 or 2.6 as Hosuk pointed out, ISE 2.3 still supported as of today, you may reach out to TAC if running any issue.
If possible, please try it out in a lab setup first.
