ISE 1.1 - Disable SSLv3 Guest Portal
joshhunter
Level 4
Level 4
Hello, are we able to disable SSLv3 protocol for Guest Portal in ISE1.1?
The customer is running 1.1 but upgrading to 1.4 shortly.
I have had a look at the documentation located here:
https://communities.cisco.com/docs/DOC-69521#jive_content_id_Web_Portals
My understanding that SSLv3 is deprecated, and should be using TLS1.0+
From reading the document linked above:
ISE 1.2 supports TLS 1.0, 1.1 and 1.2
ISE 1.3 and 1.4 support TLS 1.0 only
ISE 2.1 supports TLS 1.0, 1.1 and 1.2
Could you please confirm if SSLv3 can be disabled or the customer must upgrade to 1.2+ which supports the successor TLS1.0
ISE 1.4 is latest support for custoemrs with  ISE-3315, ISE-3355 and ISE3395, after that version 2.x requres Appliances to be SNS-34xx
http://www.cisco.com/c/en/us/td/docs/security/ise/1-4/release_notes/ise14_rn.html#pgfId-42971
6 Replies 6
hslai
The ISE 1.2 entry should be for ISE 2.0. IIRC ISE 1.2 support SSLv3.
Nonetheless, both ISE 1.1 and 1.2 are very old so please upgrade the customer to ISE 2.0.1 or newer.
A large quantity of our customer's are on the old Appliance so only 1.4 is the latest until they upgrade hardware or move to VM.
You are correct.
Okay, so I guess my question is -
Does ISE 1.4 remove SSLv3 support i.e. rather than Poodle Patch, disable completely for Portal Pages specifically Guest.
Yes, all web portals, including guest, in ISE 1.3 and 1.4.x support TLS 1.0 only.
