ISE 1.4 to 2.3 Upgrade Best Practice - 50 nodes
junk1
My enterprise customer has ISE 1.4 running in their network. The PAN and MnT are VMs and PSNs are hardware appliance 3495.
There are 37 PSNs in one cluster, along with 2 PANs and 2 MnTs. There is another cluster with 2 PAN, 2 MnT and 5 PSNs.
For future enhancement, customer had built 2 PAN and 2 MnT running ISE 2.3 which is currently not in production. Due to various reasons, customer is upgrading the ISE 1.4 to 2.3.
Customer is looking for best way to upgrade, considering all possible aspects not limited to but including the below points:
1. If upgraded, will the Profiling database be affected? If yes, then will ISE be able to re-profile or do we need to reboot the headless devices? How to avoid loosing Profiling database?
2. Node-groups are configured currently with ISE 1.4 among local PSNs. How to approach Node-group while upgrading? Do we need to upgrade both nodes in Node-groups together?
3. Currently there are 250,000 Base license in this cluster. Is it possible to split this license into a pair of 125,000?
Current plan with my customer is - Choose a location on a downtime window and upgrade all ISE nodes in that location and point them to the currently available PAN in 2.3 version.
Please share your guidance in proceeding with the right approach of ISE upgrade.
Thanks and Regards
V Vinodh.
As I have previously stated I don't use Cisco's GUI or CLI upgrade method.  Manually doing an upgrade is much safer and more predictable.  I would:
  1. Build a fresh 2.1 node and restore the 1.4 backup to it and validate everything came across just fine.
  2. Run the URT tool on the 2.1 node to ensure the 2.3 upgrade won't be an issue.
  3. Once the URT tool runs clean take a fresh backup of the 2.1 system.
  4. Build a fresh 2.3 VM or use one of your existing 2.3 VMs and restore the 2.1 backup.
  5. Validate everything restored cleanly.
  6. Rehost your licenses from 1.4 environment.  There is no checking on Cisco side when you rehost.  You simply ask to rehost and you can have 250k running in 1.4 and 250k running in 2.3.  I would advocate converting to Smart licensing through.  Cisco licensing can help you with that.
  7. Apply patch 1.
  8. Join to AD.
  9. Test the configuration by pointing test devices at the node.
  10. Once you have your 2.3 anchor point setup, running the full config and the config has been tested, the upgrade is the same for the rest of the deployment:
    1. Rebuild the system to fresh 2.3 image.
    2. Install Patch 1
    3. Install certs
    4. Join system to the 2.3 anchor point and assign correct role
    5. Join to AD
Assuming you are using load balancers you should be able to do this upgrade with minimal to no downtime seen by the clients.  I just did a 20 node upgrade over the course of two days using the method above with no downtime.  We did the whole thing during the day not during any maintenance windows.
10 Replies 10
Charlie Moreton
This will guide you through the steps required:
Upgrading to Identity Services Engine 2.1 in a Distributed Environment
Just remember that v1.4 can upgrade directly to v2.1 and then can be upgraded to v2.3
ISE Version Upgrade Matrix
  7. Apply patch 1.
  8. Join to AD.
    2. Install Patch 1
    3. Install certs
    5. Join to AD
Is there any special attention we need to pay to posture assessment and profiling?
Posture and profiling are enhanced in these releases. If you’re wondering around what please look at the release notes.
Also unless there is a specific feature you’re needing in 2.3 we are recommending that you install 2.2 with the latest patch
The main thing we're looking for to the upgrade from 1.4 to 2.2 or 2.3 is the new "posture with no redirect" flow.
You might want to take a look at the lab exercise 2 of [ISE Lab Guide] ISE 2.2 Update.
Hi Paul,
After restoring config, did you have to reconfigure ip address/hostnam of 2.3 nodes to match with the existing ISE? Or did you reconfigure the NADs and point them to the new PSNs? Thanks.
Assuming that you are not using load balancer and that you are either testing the first node or your deployment is standalone, then yes, you would need either change the IP address to match that configured on NADs or update the NADs to use the new IP address.
In case you have multiple nodes, then the restore is done on the primary ISE node only and the 2nd nodes can be de-registere from the deployment of the older ISE release, fresh installed with the same hostname and IP address info, and then join to the new deployment.
Hi Paul,
I have to upgrade our 14 node deployment and everything is all hardware. What will be your suggested approach  for this? Thanks in advance.
Create/post a new discussion detailing your hardware and if you intend to replace/reuse hardware or use virtual nodes. We can help you with the path forward.
Include your current version and patch, hardware appliance types, future state plans (reuse or replace hardware), or moving to VM's.
