ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
366
Re: ISE 2.1 FMC 6.1 ANC Unquarantine
Hi, you should be able to pull this from the ISE reports
Beginner
thanks.
So I could see information in this section? Is  that a normal behavior?
Highlighted
Yes, you should see the quarantined endpoints, and yes this is normal behavior
Beginner
Thanks John.
I mean. Is a normal behavior in this version can't see a list of quarantine devices? Is there any way to could see in the policy assignment
section?
Yup, this is normal behavior. Nope you cannot see this under the ANC policy assignment, since Firepower is using ANC 1.0, subscribing to the EndpointProtection Service Capability and using Session:EPSStatus:Quarantine for the ISE Authorization policy.
