ISE 2.1 guest portal setup without login fields
Tim Baum
Is there a way to have a guest portal for self registration without the login fields?
Or is there a way to upload HTML pages to custom build portal pages as was possible with ISE 1.4?
Tim
Jason Kunst
pre1.3 customization was different, it allowed your own HTML
Redesigned ISE in ISE 1.3+ customization is all the same so I am not sure what 1.4 offers separate? There is nothing. ISE 2.2 offers the custom portal files where you can again upload HTML but not necessarily will help you out all the way
http://www.cisco.com/c/en/us/td/docs/security/ise/2-0/admin_guide/b_ise_admin_guide_20/b_ise_admin_guide_20_chapter_010000.html#id_34829
Look for custom file upload
can you explain more the flow you need?
Check here for customization options that we have made as a community
ISE Guest & Web Authentication
7 Replies 7
Charlie Moreton
You could use this customization to redirect to the Create Account page:
Login page auto-redirect to create an account page
Jason Kunst
Customer wants to use the self registration guest portal with sponsor authorization but not the guest login. Essentially the self registration only.
Self registration with sponsor approval flow still requires the user to login to a portal
User registers
Sponsor approves
Credentials are sent to user
I am not sure what you're looking for?
We don't have a feature to allow the user to wait on a page for approval and be automatically authorized
Not the way this customer is using it.
I should add that they want to have guest register for an account on one SSID (open) then get sponsor approval. Then connect using that account on a wpa2-ent ssid. It all works but the guest portal page has that big login field in the middle we want to hide somehow, to be less confusing.
Ok that's good info!
how about just using the script that Charles shared to go directly to self registration?
