01-12-2017 01:00 PM
We have a customer that is planning an upgrade from v1.2 to v2.1. Their current Guest portal flow uses custom portal pages uploaded into ISE, so I have 2 questions.
It would probably be ideal to wait for the feature in 2.2, but the customer has concerns about the EOL of 1.2 and wants to perform the upgrade ASAP.
Thanks for your help.
Solved! Go to Solution.
01-12-2017 01:14 PM
YES, if they must upgrade would recommend 1.2 > 1.4 (latest patch) then to 2.1)
There is no upload support of HTML flows per say. you can upload to file remediation but its not meant for special customized flows
2.2 has custom portal files supported. 1.4, 2.1 can use the file remediation location. https://supportforums.cisco.com/discussion/12344731/ise-13-portal-customization-background-image
You should be looking into deploying 2.1 in the lab and doing a fresh install and having the custom rebuild using the new concept. It sounds like its complex as well. I really only recommend using the portal upgrade as a stop gap. They might even look into the ISE portal builder for support if they don't have the expertise.
Perhaps a parallel system on ISE 2.1.
see the notes on custom portal migrations
Release Notes for Cisco Identity Services Engine, Release 1.3 - Cisco
01-12-2017 01:14 PM
