ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
375
Highlighted
ISE 2.1 support for CSM 4.11
Hi All,
Will ISE 2.1 TACAC+ support CSM 4.11 for user role auth?
thanks
Alistair
1 ACCEPTED SOLUTION
Re: ISE 2.1 support for CSM 4.11
6 REPLIES 6
I am hoping the same as it is strait forward TACACS+ :-),
I do want to verify as it is a critical component for a major project that is pending investment.
Alistair
Good day, can ISE be used for Role Authorization for CSM users as it was available in ACS 4.x?
In a way similar to this: Cisco Security Manager - Integration wi... - Cisco Support Community
Best regards,
Dmitry Kazakov
Yes similar to what hsing said above
Its similar concepts just new UI, please lab it up and let us know
If you’re able to share some notes afterword that would help
Above there was Tacacs+ Authentication and LOCAL role Authorization.
In my case customer asks for Tacacs+ Authentication and Tacacs+ role Authorization.
We just can't understand or find any docs on how to make Role assignment in CSM through Tacacs+.
Sorry might be you have to work with CSM tac or someone on their support to come up with some new tech notes using ACS guide and revamping
