ISE 2.2 -> 2.4 URT fails at Data upgrade step 1/43, UPSUpgradeHandler
Filip Po
URT test fails on ISE 2.2 Patch 14.
Can anybody read the log and tell me, what is wrong in the First Rule of Policy Set?
Running data upgrade on cloned database
- Data upgrade step 1/43, UPSUpgradeHandler(2.3.0.100)... Failed.
- Failed
Condition:Snímka obrazovky 2019-07-19 o 14.06.08.png
@@@ PsUpgrade:	debug- : Found allow value for Network Access:Protocol0:RADIUS
@@@ PsUpgrade:	warn- :Couldn't buildConditionDataForNameValue for: lhsAttrId:DEVICE.Device Type rhsString:null:Device Type#All Device Types#ASA FW, Will try to build it from rhs value
com.cisco.cpm.policy.pal.PalException: Value for attribute is not a permitted option
	at com.cisco.cpm.policy.pal.policyCondition.ConditionsData.validateAllowedValues(ConditionsData.java:545)
	at com.cisco.cpm.policy.pal.policyCondition.ConditionsData.initSimple(ConditionsData.java:438)
	at com.cisco.cpm.policy.pal.policyCondition.ConditionsData.<init>(ConditionsData.java:299)
	at com.cisco.cpm.policy.configuration.upgrade.PolicyUpgradeUtil.buildConditionDataForNameValue(PolicyUpgradeUtil.java:947)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradeNetAccessRuleBuilder.buildConditionDataClauseSimple(UpgradeNetAccessRuleBuilder.java:152)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradeNetAccessRuleBuilder.buildConditionDataClauses(UpgradeNetAccessRuleBuilder.java:99)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradeNetAccessRuleBuilder.buildRuleConditionData(UpgradeNetAccessRuleBuilder.java:70)
	at com.cisco.cpm.policy.configuration.upgrade.builder.AbstractUpgradePolicyDataBuilder.buildNetAccessRuleConditionData(AbstractUpgradePolicyDataBuilder.java:78)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradePolicyDataBuilderRadius.buildNetAccessRuleConditionData(UpgradePolicyDataBuilderRadius.java:200)
	at com.cisco.cpm.policy.configuration.upgrade.builder.AbstractUpgradePolicyDataBuilder.buildPSLevelConditionsData(AbstractUpgradePolicyDataBuilder.java:64)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradePolicyDataBuilderRadius.buildUpgradeData(UpgradePolicyDataBuilderRadius.java:76)
	at com.cisco.cpm.policy.configuration.upgrade.PolicyUpgrade.upgradeLegacySetRadius(PolicyUpgrade.java:394)
	at com.cisco.cpm.policy.configuration.upgrade.PolicyUpgrade.upgradeLegacySet(PolicyUpgrade.java:337)
	at com.cisco.cpm.policy.configuration.upgrade.PolicyUpgrade.upgradeLegacySets(PolicyUpgrade.java:213)
	at com.cisco.cpm.ups.upgrade.impl.PolicyUpgradeHandler.importData(PolicyUpgradeHandler.java:67)
	at com.cisco.cpm.ups.upgrade.UpgradeHandler.exportAndImport(UpgradeHandler.java:38)
	at com.cisco.cpm.ups.upgrade.UpgradeHandler.execUpgrade(UpgradeHandler.java:29)
	at com.cisco.cpm.ups.upgrade.impl.UPSUpgradeHandler.upgrade(UPSUpgradeHandler.java:154)
	at com.cisco.cpm.infrastructure.upgrade.impl.UpgradeServiceRegistrar.UpgradeServices(UpgradeServiceRegistrar.java:132)
	at com.cisco.cpm.infrastructure.upgrade.impl.UpgradeServiceRegistrar.main(UpgradeServiceRegistrar.java:185)
@@@ PsUpgrade:	debug- :Trying to rebuildConditionDataForNameValue  for: lhsAttrId:DEVICE.Device Type rhsString:Device Type#All Device Types#ASA FW
@@@ PsUpgrade:	info- :Successfully rebuildConditionDataForNameValue for: lhsAttrId:DEVICE.Device Type rhsString:All Device Types#ASA FW
@@@ PsUpgrade:	debug- :Reading Authentication rules for Policy Set ASA FW Rule
@@@ PsUpgrade:	debug- :Reading Default Authentication rule for Policy Set ASA FW Rule
@@@ PsUpgrade:	debug- :Build authentication result data for default rule  of Policy Set  ASA FW Rule
isPolicySetModeActivated --> pss.getPolicySetMode() = POLICY_SET
-->validatePolicyMode, isArrivingFromPolicySetAPI= true
-->validatePolicyMode, PolicySetRestService.isPolicySetModeActivated() = true
@@@ PsUpgrade:	debug- :Built authentication result for rule Default with following attributes: Identity Source=Internal Users, If Auth fail=REJECT, If Process fail=DROP, If User not found=REJECT
@@@ PsUpgrade:	debug- :Found 1 non default Authentication rules for Policy Set ASA FW Rule
@@@ PsUpgrade:	debug- :Reading Authentication rule ASA VPN AuthC  of Policy Set  ASA FW Rule
@@@ PsUpgrade:	debug- :About to get condition RHS display value for Network Access with attribute Protocol
@@@ PsUpgrade:	debug- :Network Access:Protocol has allow values enumeration
	at com.cisco.cpm.policy.configuration.upgrade.builder.AbstractUpgradePolicyDataBuilder.buildAuthenticationRules(AbstractUpgradePolicyDataBuilder.java:128)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradePolicyDataBuilderRadius.buildUpgradeData(UpgradePolicyDataBuilderRadius.java:96)
@@@ PsUpgrade:	debug- :Build authentication result data for rule ASA VPN AuthC in Policy Set ASA FW Rule
@@@ PsUpgrade:	debug- :Build authentication rule result data for outer rule ASA VPN AuthC
@@@ PsUpgrade:	debug- :Reading authentication inner rules for PS: ASA FW Rule
@@@ PsUpgrade:	debug- :Build authentication rule result data for outer default rule
Retrived the data from Handlercom.cisco.cpm.ups.upgrade.impl.PolicyUpgradeHandler]
com.cisco.cpm.infrastructure.upgrade.api.UpgradeFailureException: java.lang.NullPointerException
	at com.cisco.cpm.ups.upgrade.UpgradeHandler.exportAndImport(UpgradeHandler.java:41)
Caused by: java.lang.NullPointerException
	at com.cisco.cpm.policy.configuration.upgrade.builder.AbstractUpgradePolicyDataBuilder.buildAuthenticationRuleResultDataForOuterDefaultRule(AbstractUpgradePolicyDataBuilder.java:284)
	at com.cisco.cpm.policy.configuration.upgrade.builder.AbstractUpgradePolicyDataBuilder.buildAuthenticationInnerRules(AbstractUpgradePolicyDataBuilder.java:182)
	at com.cisco.cpm.policy.configuration.upgrade.builder.UpgradePolicyDataBuilderRadius.buildUpgradeData(UpgradePolicyDataBuilderRadius.java:99)
	... 4 more
 Error while applying changes in version: 2.3.0.100 class: com.cisco.cpm.ups.upgrade.impl.UPSUpgradeHandler
com.cisco.cpm.infrastructure.upgrade.api.UpgradeFailureException: Failed to upgrade to version 2.3.0.100: java.lang.NullPointerException
	at com.cisco.cpm.ups.upgrade.impl.UPSUpgradeHandler.upgrade(UPSUpgradeHandler.java:162)
ERROR! isedataupgrade.sh FAILED. ISE GLOBAL DATA UPGRADE FAILED
Please work through the TAC as they should help you and make sure everything is good before you proceed. They can also use their knowledge and open bugs if necessary. Make sure you are running the latest patch as well before running the tool
Surendra
Looks like there is a white space before “Device Type#All Device Types#ASA FW”. Please rebuild that condition and it should go through. If you have similar rules, recommend you to do the same for them as well.
Unfortunately, I created a really new Rule (ASA FW Rule NEW) from scratch with the same values as the old one. But the result is the same.
All Device Types is system Network Device Group and it can't be changed.
@@@ PsUpgrade:	debug- :Reading Authentication rules for Policy Set ASA FW Rule NEW
@@@ PsUpgrade:	debug- :Reading Default Authentication rule for Policy Set ASA FW Rule NEW
@@@ PsUpgrade:	debug- :Build authentication result data for default rule  of Policy Set  ASA FW Rule NEW
@@@ PsUpgrade:	debug- :Built authentication result for rule Default with following attributes: Identity Source=All_User_ID_Stores, If Auth fail=REJECT, If Process fail=DROP, If User not found=REJECT
@@@ PsUpgrade:	debug- :Found 1 non default Authentication rules for Policy Set ASA FW Rule NEW
@@@ PsUpgrade:	debug- :Reading Authentication rule ASA VPN AuthC  of Policy Set  ASA FW Rule NEW
	at
