03-08-2017 10:58 AM
Is there a way to utilize the schema options to map the email attribute to the UPN field? I have a customer that wants to use the one-click approval but the email attribute that is associated with the active directory user accounts are not being used. When they send emails out to users, they send it to the address within the UPN field.
Solved! Go to Solution.
03-20-2017 10:15 AM
How about this, under the user info attributes put the UPN in for email, this will map your UPN to the email address field on ISE
03-08-2017 11:07 AM
I will check, pretty sure the answer is no
https://communities.cisco.com/docs/DOC-70777
What type of accounts are able to use the single click with token?
The sponsor email address must be populated under the AD or LDAP account Email.
ISE AD/LDAP schema is already mapped out of box when configured.
Administration > Identity Management > External Identity Sources > Active Directory > domain > Advanced Settings > Schema
03-20-2017 10:15 AM
04-01-2017 10:23 AM
Using a custom schema doesn't work......I've opened a case at Cisco few weeks ago, it should be an enhancement in the future.
I can't use use the one click feature because of that :
ENH: One-Click approval does not work with the "Only accounts assigned to this sponsor" option.
CSCvd29533
This enhancement is not expected in the first patch. For me it's a bug since I can't use this feature.
04-01-2017 11:08 AM
i checked with development and they said to try what I listed above
if not please list the bug you had for that
the other issues is known defect working with development on
04-03-2017 06:15 AM
I've just received the BUG ID for the schema : CSCvd85620. It may not be visible at this time but it should be soon.
Apparently, they've released the one click feature without try it :-).
