04-17-2019 02:23 PM
Team,
How long will ISE 2.2 be support now that 2.4 is recommended? AS team is deploying 2.2 (been going on before 2.4 was out due to customer) we need to understand when the customer will be forced to upgrade.
Solved! Go to Solution.
04-22-2019 09:42 PM
Please check the ISE product bulletin for ISE release life cycle
I have detailed how it works in ISE upgrade guide if you are not clear and added EOL of all the releases so far.
https://community.cisco.com/t5/security-documents/ise-upgrades-best-practices/ta-p/3656934
Krishnan
04-17-2019 02:50 PM
04-17-2019 05:05 PM
Jason's PM contact link is probably best for internal teams. For external though, there was the ISE product life cycle bulletin posted back in 2018. It gives us enough information to ball park it, and also notice that the timeline provides two and a half years to upgrade. 18 months of software maintenance, followed by 12 more months of support.
https://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/bulletin-c25-740738.html
2.0 released on Mar 17th 2016 and the announced end of support date is Mar 17th 2021.
2.2 released on Jan 31st 2017. Based on the bulletin I would have expected 2.2 to have an announced EOL already, ending support around the same time as 2.0. If we follow the timeline though, adding 30 months from today, 2.2 could potentially go end of support Oct 31, 2021.
Following this logic, 2.4 could have an end of support date around Mar 28th 2022, and 2.6 around Feb 18th 2023.
Other than 2.0, none of these dates are set in stone, just estimations based on release dates and the published product life cycle.
04-22-2019 09:43 PM
04-22-2019 09:42 PM
Krishnan
