ISE 2.3 Support for Forcepoint NGFW
xayxa30
Does anyone have any resources on how to use TACACS with Forcepoint NGFW?
I assume I have to import a RADIUS dictionary [if they have it] from the vendor before I can try to create a profile for it ?
Does the RADIUS dictionary cover TACACS ? I did not see vendor specific listings under TACACS in the dictionary.
Pete
2 Accepted Solutions
Francesco Molino
I'm not very familiar with Forcepoint but searching what kind of external authentication they support, I've found that your tacacs or radius will be only for authentication and you'll need to create the user locally on your system for authorization purpose (https://help.stonesoft.com/onlinehelp/StoneGate/SMC/6.3.0/GUID-26D7F914-2335-4D52-BE07-869BD6D165FD.html)
In that context, you don't need to import any dictionary.
If you have a specific documentation stating otherwise, please share it.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
You're welcome. Glad it works!
Francesco
Francesco Molino
Francesco
Okay thanks for the clarification. I got it working and as you say no vsa imports needed.
Francesco
