ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
151
Highlighted
Rising star
ISE 2.4: 802.1x authz criteria by access vlan
Hi everyone,
Is it possible to add the switchport's access vlan as a criteria for 802.1x authorization?
For example, check certificate AND (supplicant is connected to access vlan 1020 OR access vlan 1025). Only then permit access.
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Advocate RJI VIP Advocate
VIP Advocate
Re: ISE 2.4: 802.1x authz criteria by access vlan
This is certainly possible using IBNS 2.0, you need to create an attribute list and include the vlan-id. E.g:-
access-session attributes filter-list list ATT_LIST
 vlan-id
access-session authentication attributes filter-spec include list ATT_LIST
access-session accounting attributes filter-spec include list ATT_LIST
The ISE AuthZ rule would check for the condition "Radius:Tunnel-Private-Group -ID CONTAINS DATA" - where DATA is the name of the vlan
SWI-2#show vlan
VLAN Name Status Ports
1 default active Gi0/11, Gi0/12, Gi0/13, Gi0/14
Gi0/15, Gi0/16, Gi0/17, Gi0/18
Gi0/19, Gi0/20, Gi0/21, Gi0/22
Gi0/23, Gi0/24
10 VLAN0010 active
11 DATA active Gi0/2, Gi0/3, Gi0/4, Gi0/5
Reference here
4 REPLIES 4
Rising star
 - The supplicant is not connected to a VLAN but runs on the end-host. You define in in the ISE-policy which VLAN the host will be put in.
 M.
Rising star
Not quite what I'm asking. I'm not interested in assigning VLAN dynamically by policy, but rather receive the switchport's existing access VLAN as part of the access-request (or any other mechanism).
VIP Advocate
 vlan-id
SWI-2#show vlan
Gi0/23, Gi0/24
10 VLAN0010 active
Reference here
Rising star
IBNS 2.0 requires fairly modern hardware (3850 and later, for example). Any idea for a solution based on the 3750 platform?
