ISE 2.4 issue with deleting a certificate CSCvj11476
rajulpar
Hi All,
Any one knows what will be fixed for CSCvj11476  ( issue with recreating certificate or deleting certificate )
Has it been fixed in ISE 2.4 patch 2 ?
Any remediation to handle this situation when we need to replace the any certificate or deleting certificate?
Arne Bier
I have never run into this issue before (touch wood!).  I know that if you try deleting a portal certificate that is still linked to one or more portals, then ISE will display a useful error message telling you wish portal it's linked to.
Arne Bier
Thanks Arne:)
It is annoying, I know.
I also found following issue while rebuilding the Node.
Application server went to running to not running  to initializing state to running state
Any clue ?
 ise24-fd1 logger: info:[application:operation:appservercontrol.sh] Starting ISE Application Server...
 ise24-fd1 ll[13735]:  2061, type=USER, name=Application server status, username=system, cause=Application server started, adminipaddress=
111.0.0.1, interface=CLI, detail=Application server started
ise24-fd1 ADE-SERVICE[1158]: [16653]:[info] application:operation cars_install.c[2443] [admin]: Application initialization initiated for appname: ise, op
eration: 3
ise24-fd1 ADE-SERVICE[1158]: [16653]:[info] application:operation cars_install.c[2501] [admin]: Operation of application complete - out = ISE PROCESS NAM
ESTATE            PROCESS ID  #012--------------------------------------------------------------------#012Database Listener                      running          5
649        #012Database Server                        running          113 PROCESSES#012Application Server                     initializing                 #012Profiler Database
             running          7997        #012ISE Indexing Engine                    not running                  #012AD Connector                           not running
#012M&T Session Database                   running          7634        #012M&T Log Collector                      running          15808       #012M&T Log Processor
 running          15703       #012Certificate Authority Service          not running                  #012EST Service                            not running                  #012SXP Engi
ne Service                     disabled                     #012Docker Daemon                          running          9940        #012TC-NAC Service                         disabled
     #012#012#012#012Wifi Setup Helper Container            disabled                     #012pxGrid Infrastructure Service          initializing                 #012pxGrid Publisher Subs
criber Service    initializing                 #012pxGrid Connection Manager              initializing                 #012pxGrid Controller                      initializing
     #012PassiveID WMI Service                  disabled                     #012PassiveID Syslog Service               disabled                     #012PassiveID API Service
      disabled                     #012PassiveID Agent Service                disabled                     #012PassiveID Endpoint Service             disabled                     #012Pas
siveID SPAN Service                 disabled                     #012DHCP Server (dhcpd)                    disabled                     #012DNS Server (named)                     disabl
ed                     #012ISE RabbitMQ Container                 running          11463
I am having the same issue in 2.3 patch 1.  I am upgrading to 2.4 patch 5.  I am running the URT and it will not run since one trusted certificate failed. Will I still  be able to complete the upgrade?
