01-22-2019 11:54 AM
Hello team,
Can someone please point me to documentation that shows all of the ISE 2.4 licensing changes and how existing deployments will be affected after the upgrade?
I know that one example of the 2.4 changes is with TACACS. TACACS licenses are now required per node and no longer per deployment. For existing customers, the customer is entitled to 50 node licenses. My customer is running version 2.3 and would like to know what changes to expect when the company upgrades to 2.4 .
Best Regards,
Lauren White
Solved! Go to Solution.
01-22-2019 08:33 PM
Please refer ordering guide - https://www.cisco.com/c/dam/en/us/products/collateral/security/identity-services-engine/guide_c07-656177.pdf
You can refer the 'Frequently Asked Question' section.
Nidhi
01-22-2019 01:53 PM
01-22-2019 08:33 PM
Nidhi
