ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
142
Beginner
ISE 2.4 Licensing
Is a new license required to upgrade 2.1.x to 2.4?
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Highlighted
VIP Engager
Re: ISE 2.4 Licensing
Not exactly. If you're running ISE hardware and have SNS3515/3595 appliances you don't need to do anything. If you are hardware and on 3400's or older then you won't be on 2.4 supported hardware.
If you're running ISE VM's then you need to convert your existing right to use VM licenses to 2.4+ VM licenses. The process to do this is really simple, you email ise-vm-license@cisco.com with your relevant Cisco sales order numbers. You will be issued a new PAK with the same number of new VM medium licenses that you own. You can do this before or after your upgrade without impact.
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-24/213171-ise-2-4-upgrade-alarms-fewer-vm-license.html
"If you are planning to upgrade to Release 2.4, contact ise-vm-license@cisco.com with sales order numbers that include VM purchase to procure one medium VM license for each VM previously purchased. You should also include your CCOID along with the sales order number. Alias is only for previously purchased customers who wish to upgrade to 2.4 and need PAKs. New customers are expected to channel their purchases through direct sales or partners who will walk them through the regular buying process."
VIP Engager
Also Device Admin license is per node in 2.4, but if you have Device Administration license currently you will get 50 2.4 device admin licenses.  I would encourage you to convert to Smart Licensing when going to 2.4.  Smart Licensing makes things easier going forward in my opinion.
3 REPLIES 3
Highlighted
VIP Engager
VIP Engager
Beginner
Exactly what I needed. Thank you!
