06-13-2018 02:25 PM
Greetings Experts,
Does ISE 2.4 Authorization policy have the option to do "Multiple Matched Rule Applies"?
Br,
Asif
Solved! Go to Solution.
06-13-2018 06:26 PM
Multi-match was only supported in Simple Policy mode and currently deprecated in 2.3/2.4 where strictly Policy Set mode.
Craig
06-13-2018 02:29 PM
Asif,
I don't have any of my customers at 2.4 yet, but I don't think this is supported. What is the use case you are trying to solve?
06-13-2018 02:32 PM
Customer need to match multiple authorization profiles based on matched rules which existed in 2.2. However after upgrade to 2.4, we can only see Default policy set and don’t have the option to “Multiple Matched” rule under Authorization policy.
Asif A
06-13-2018 03:15 PM
Hello Asif,
I have run many ISE implementations but I am not familiar with any ability to match multiple authorization rules. Typically you build ISE on a first match design. You can create multiple policy sets, each policy set will have authentication conditions that must be matched. Once you match an authentication rule in a policy set you then hit a configured authorization rule.
Within both the authentication rules and authorization rules of a policy set you can set up compound conditions. These conditions must be met to be matched.
It sounds like when you upgraded it might have merged your existing 2.2 policy set incorrectly, or in a way that doesn't match your needs. You shouldn't need to match two rules to authenticate the same endpoint.
06-13-2018 06:26 PM
Craig
