08-09-2018 11:58 AM
HI All,
I'm attempting to deploy a 2.4 ISE OVA here in our lab and I'm getting a validation error against the ova when selecting a compute resource, before I even try to actually deploy it. Just wondering if anyone's seen this before?
Solved! Go to Solution.
08-09-2018 10:56 PM
I checked with the internal team and looks like this is a known issue.
OVA templates are not compatible with VMware web client for vCenter 6.5. As a workaround, use the VMware OVF tool to import the OVA templates.
Nidhi
08-09-2018 12:05 PM - edited 08-09-2018 12:12 PM
I did check the md5 checksum for the file I downloaded and it does match what's up on the software download page.
08-09-2018 02:22 PM
08-09-2018 09:20 PM
Do you have a TAC case opened for this ? Can you send me the SR number ?
Please open a TAC case if not already done
08-09-2018 10:56 PM
Nidhi
08-10-2018 09:15 AM
Is there any document or guidelines for this known issue? I’m going to work with our data center team to deploy 2.4 ova. For sure they will raise question. Any document will be helpful to facilitate my conversation. Thanks in advance.
08-10-2018 09:54 AM
See if this helps -- Re: ISE 2.2 and 2.3 and vCenter 6.5 - .ova still not working!!!
08-10-2018 11:44 AM
