02-07-2019 11:23 AM
I am trying to upload offline as well online the latest ISE Profiler Feed update to an ISE 2.4 Patch2 deployment. Both methods are failing and currently investigating the root cause with TAC. While troubleshooting we've observed that the Profiler feed update contains the following elements :
----8<----
Cisco ISE Feed Service - Offline Update Package
Package Creation Date: Wed Feb 06 06:00:59 PST 2019
This report lists the approved device profiles contained in this Offline Update Package.
Device profiles in each feed are listed newest first.
Feed: Profiler:1 (203 approved device profiles)
Feed: Profiler:2 (73 approved device profiles)
Feed: Profiler:3 (17 approved device profiles)
Feed: OUI (OUI data was last updated from IEEE on Wed Feb 06 05:11 PST 2019)
---->8--------
Shouldn't there be a Profiler:4 set as well, including new profiles added with ISE 2.4 ?
Many thanks
Istvan
Solved! Go to Solution.
02-09-2019 08:14 PM
I do not think we added any new profiles specific for ISE 2.4 in the profiler feed. The main change in ISE 2.4 is the addition of IoTAsset dictionary and the profiles are in the community -- Cisco ISE Industrial Network Director (IND) IoT Profile Library v1.0
02-08-2019 09:11 PM
Please continue working with the TAC to determine the root cause.
02-09-2019 08:14 PM
