04-23-2019 06:52 AM
I want to config a 2 node ISE 2.6 deployment using VM's and I want those VM's to be sized as SNS 3655 appliances. What ISE VM licenses are required for each VM? Is it R-ISE-VMM-K9= or R-ISE-VML-K9=? The odering guide is confusing. I have been under the impression that the R-ISE-VML-K9= license is only to be used for an M&T node.
Solved! Go to Solution.
04-23-2019 08:47 AM
Yes that would be sufficient, you can support 25k active endpoints in a hybrid or standalone deployment leveraging 3655 medium templates.
04-23-2019 06:58 AM
04-23-2019 07:04 AM
Thanks Damien. I want to configure an ISE 2.6 solution in a campus environment. 13,000 max simultaneous endpoints (mix of wired/wireless endpoints) connecting at the same time. Will do profiling but no posture. Currently I think I can use a 2 node deployment (all personas on each node) using VM's and sizing the VM's as SNS 3655 nodes.
04-23-2019 08:47 AM
