02-21-2017 12:48 PM
Team,
Starting in 2.0, ISE supports posture checks for disk encryption for Windows and Mac clients. However you have to specify the vendor when you define the posture condition. Is there a plan to add the functionality for an administrator to create a posture condition which checks for "Any" Vendor or is this a limitation with OPSWAT directly?
Thomas Wall
Solved! Go to Solution.
02-21-2017 12:59 PM
This might work for you (I am using ISE 2.2):
Create an Application Condition, Choose the Operating System, Check By Application. Choose the Application State you want to check (Installed, Running, or Both), Provision by Category and choose Encryption.
02-21-2017 12:59 PM
02-21-2017 01:10 PM
Thank you for the prompt response! I'll test this workaround out.
