ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
164
ISE 802.1x audit
Hello
Customer is rolling out 802.1x to 2000 switches, and needs the ability to audit all the access ports to determine the  configuration state of 802.1x  on the port.
does ISE have reporting to help with this process?
thanks.
3 ACCEPTED SOLUTIONS
Re: ISE 802.1x audit
It doesn't. This would be a management system like prime. Cisco Active Advisor was something that was supposed to do this as well. Not sure if it does. Trying to find this out
https://www.cisco.com/c/en/us/products/cloud-systems-management/active-advisor/index.html#~stickynav=2
Thats right Jason.. Outside Prime, dont think we have any readily available Cisco Tools which can do so..
https://cway.cisco.com/cli/  -- Check this, but it still manual..
Next option may be to run a script which basically needs to collect & archive multiple versions and then compare a baseline version vs captured configs and highlight the differences.
Highlighted
One of our partners Secureview has a tool for this, try it out:
https://www.securview.com/products/cisco-ise-deployment-assistant/
-Hari
4 REPLIES 4
cli analyzer... looks pretty slick. ==> downloading now.
and thanks for recommendation; will need to continue exploring. as this requires analysis of over 2K switches, something automated is definitely needed. or a whole lot of interns :)
cheers.
Regan
Highlighted
-Hari
