08-30-2017 05:41 PM
This may seem like a dumb question but I haven't been able to locate anything which gives me a simple answer. We want to do a simple Airwatch integration whereby if a device is not compliant it cannot join the SSID. What ISE licensing is required for this scenario?
Alan
Solved! Go to Solution.
08-30-2017 06:00 PM
Apex
The client would join the network but be authorized as quarantine
This is called mdm integration
08-30-2017 06:00 PM
Apex
08-30-2017 06:00 PM
IT is also known as device compliance
