ISE and Nexpose integration TC-NAC
ksastoqu
Hello Team,
I have a customer that is trying to integrate ISE 2.6 to a Nexpose server. He completed all steps on this link https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-22/200974-Configure-ISE-2-2-Threat-Centric-NAC-TC.html#anc4 but when adding the nexpose server, he gets the error "Error connecting to the Nexpose server, Error parsing response of Login request".
From the logs from TC-NAC and ANC, the only error they're showing is the same above. These are some of the logs:
2019-08-20 11:21:47,818 DEBUG  [SimpleAsyncTaskExecutor-1][] ise.va.adapter.amqp.RabbitMqUtil -:::::- Sending message {"schema":{"title":"Enter Nexpose Security Console credentials","type":"object","properties":{"restApiHost":{"title":"Nexpose Host","description":"The hostname of the Nexpose Security Console Host.","type":"string","minLength":"4"},"restApiPort":{"title":"Nexpose port","description":"The port of the Nexpose Security Console host.","type":"integer","default":"3780","minimum":"1","maximum":"65536"},"description":"Username to access Nexpose Security Console.","type":"string","minLength":"4"},"description":"Password of the user.","type":"string","format":"minLength":"4"},"proxyHost":{"title":"Http proxy Host","description":"Optional http proxy host. Requires proxy port also to be set.","type":"string"},"proxyPort":{"title":"Http proxy port","description":"Optional http proxy port. Requires proxy host also to be set.","type":"integer"},"_internal_":{"type":"object","properties":{"uid":{"type":"string"},"pageNumber":{"type":"number"},"requiresFormSubmit":{"type":"boolean","default":"true"}},"options":{"hidden":"true"}}}},"data":{"restApiHost":"nc-nccdc-r7.netcloud.local","restApiPort":"3780","proxyHost":"","proxyPort":"0","_internal_":{"requiresFormSubmit":true,"pageNumber":"1","uid":"RESTCONFIG"}},"meta":{"status":"In progress","hasAdvancedSettings":false},"error":{"messages":["Error connecting to Nexpose server, Error parsing response of Login request"]}} using queue:exchange:routingkey = irf.queue.core-engine:null:irf.queue.core-engine
2019-08-20 11:21:49,930 DEBUG [main][] cisco.ise.va.adapter.Adapter -:::::- Waiting for Adapter to get configured before considering adapter as Active
The TCP dump between ISE and Nexpose server is ok, no errors or issues are shown there.
Please see the screen shot for the error he gets on ISE GUI.
Is there anything else I should be checking? Is there maybe a defect reported for this?
Thanks in advance
Jason Kunst
Jason Kunst
Please work through the Cisco TAC for troubleshooting
I do see some guides out there as well https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-22/200974-Configure-ISE-2-2-Threat-Centric-NAC-TC.html
