ISE BYOD portal error- failed to register the device'
vinmangal
Hi Cisco expert team,
Need your help to resolve this issue.
I have built WiFi test lab set-up with dual SSID to test smart phones on boarding , registration, certificate provisioning etc.
I am using two Cisco ISE ( as Admin, MnT and other one as PSN ) on version 2.3, patch 5
When I try to register any phone or laptop on BYOD portal. It throws error- "failed to register the device".
I am not sure why ISE is not letting me register any Android, Laptop or any smart phones on BYOD portal.
I can not see any error in Radius logs on ISE for why device failing to  register.
Please advise if you know the solutions. I am using EAP-TLS based authentication.
1st SSID - MAB based authentication  for on-boarding phones
2nd SSID- Dot1x based authentication for already registered phones on 1st SSID.
Vinay
2 Accepted Solutions
Jason Kunst
Many Thanks Jason for sharing this pdf document.
Issue got resolved after re-creating duplicate BYOD Portal from existing one.
Byod portal got corrupted for some unknown reason.
Jason Kunst
Have you went through this guide?
https://community.cisco.com/t5/security-documents/cisco-ise-byod-prescriptive-deployment-guide/ta-p/3641867
I would recommend tac to help troubleshoot
Thank you
