ISE + Catalyst 9300
gacs
Hi Team,
Based on ISE Compatibility matrix, Catalyst 9300 is supported.
Could You please confirm, both, Network Essentials and Network Advantage licenses are supported and tested?
Of course, Data sheet sheet shows only Network Advantage MACSec-256:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/data_sheet-c78-738977.html
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/compatibility/b_ise_sdt_24.html#supportedciscoaccessswitches
Best regards, Gyorgy
2 Accepted Solutions
Ise requires base, plus or apex , if you get these licenses with your bundle then ISE features will work
https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/admin_guide/b_ise_admin_guide_23/b_ise_admin_guide_23_chapter_0110.pdf
base inclused macsec
hslai
The 9300 licensing packages are more for features in DNA. Since ISE works with the base licensing package of 9300, no need to specify such in the ISE compatibility matrix or tested by our team.
8 Replies 8
Nidhi
These license package includes switching capabilities. You might want to post this query in switching community
Nidhi
gacs
Hi Nidhi,
In ISE services  (AAA, guest, posture, TrustSec) point of view, beyond the documented MACSec128 vs 256 support, do these licenses have any difference?
Thank You!
Nidhi
I  believe the default license should enable these ISE services. However, I am checking with the QA team here to get some more details on this .
Nidhi
Thank You, Nidhi and Jason,
ISE part is clear. The question is whether ISE Business Unit successfully tested
and validated both license versions of Catalyst 9300 switches, which I guess because
there is no specific license mentioned in the compatibility matrix.
gacs
Hi Nidhi,
Is there any answer from the QA team?
Thank You!
hslai
ISE + Catalyst 9200
Hello team,
Please can you confirm the ISE compatibility with switch c9200 series and c2960X ,
thank you
