ISE Central Web Authentication
hi all,
now I faced this issue
-First I login to SSID and then redirect to ISE guess portal.
-login with ISE local account and successful authentication.
-After that, I tried to use internet browsing and then Redirect again and again to ISE guess portal.
Please Check My ISE Authorization Rule as follow.
Thanks You
tertang@cisco.com
there's no match on your "wireless guess" authz policy after a successful web-auth that's why you get stuck in a authz loop.
take a look at your guest portal configurations>>guest type.
your "wireless guess" policy is matching on " "GuestEndpoints", so you need to make sure you assign the guest device to GuestEndpoints in Guest Types.
tertang@cisco.com
ldanny
Hi Nyi,
Its hard for me to say as I dont know how you setup your authz profile
Basically you should have 2 rules , the second one being the redirect and the first to permit access .
The second rule is the first rule to be hit ( match the re-direction ) once user logins he is sent a CoA for re-authentication and will hit the first rule which permits the access.
Check this guide to verify your setup.
How To: ISE Guest & Web-Authentication Design Guide
Danny
