Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
450
Enthusiast
ISE Client provisioning portal Cert error
When a client connects to the network and or VPN they do to hit ISE for posture scan, but always prompted its an untrusted server. The Issue I am going to have is I will have PCs connecting to this from 2 different forests and contractors that do not have company issued laptops so they will get a prompt also. So are people using third party certs for their provisioning portals and guest wifi portals?
1 ACCEPTED SOLUTION
5 REPLIES 5
Highlighted
Enthusiast
Re: ISE Client provisioning portal Cert error
I figured. I mean thats probably the best way anyway.
Enthusiast
Maybe I am missing it but when I get a third party cert from like verisign where is the section to create the cert request?
Participant
You should be able to generate the CSR by going to Administration > Certificates > Certificate Signing Requests > Generate Certificate Signing Request (CSR) in ISE.
Enthusiast
Back to this for a min. Unless I had a wildcard trusted third party cert I would need an individual cert for every portal I want to protect with ssl correct? So if I have a password portal called passwordreset.domain.com and a client provisioning portal called client.domain.com I would need to certs? How do I generate the csr for each one?
