07-29-2019 08:51 AM
Hi Team,
Is there any Common Criteria certification for ISE current versions ?
I found some information about CC certifications for ISE version 2.0 and 2.2, is there any update ?
Thanks in Advance,
Guillermo.
Solved! Go to Solution.
07-29-2019 09:21 PM
The response I have from BU is this - ' ISE 2.6 is listed on the NIST website as in-process.'
07-29-2019 09:09 AM
Hello Guillermo,
I could not find any update for the new versions. But Let me check with internal teams to confirm this.!
Nidhi
07-29-2019 09:21 PM
07-29-2019 11:33 PM
Thx Nidhi.
