ISE Compound conditions not working
AK002
Can someone help me to check this issue..
When making changes to the authentication policy, editing compound conditions is no longer working.
Patches applied and current version: ISE version 2.1.0.474, Patches 1,6 and 7 have been installed. Struts patch has also been applied..
Regards,AK
Hi Arun,
Please check in different browser,If that doesn't help, check with TAC engineer for this!
-Aravind
7 Replies 7
Can you attach the image again?
-Aravind
Here you go,, Attached the screen shot. if we click compound condition nothing is opening.
Hi Arun,
-Aravind
ldanny
Make sure to clear your browser cache as well and try different ones as well.
If nothing else helps I suggest you open a case with TAC.
Tried different browsers but same result, restarted the service still issue persist.
AK
Do you have any adblock running? adblockplus blocks some of the javascript in various ISE pages.
No Ad block running.i can say it's not a browser issue as far as we seen..
