Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
95
Highlighted
ISE Dedicated MnT-Scale Options
What scale or performance increases can we get if we break out MnT on its own? If we have VMM for PAN+PxGrid, MnT, PSN (RADIUS, TACACS+).  Is this any better then combining PAN+PxGrid+MnT? This would all be ISE 2.4
Another question, if we are only doing 2 PxGrid connections does this still reduce the scale of the over all system? Is it better to have this standalone?
Everyone's tags (3)
2 REPLIES 2
Re: ISE Dedicated MnT-Scale Options
The only benefits you get are more endpoints when you split out pan mnt either on their own or combined
You wouldn’t run pxgrid on stand-alone with pan . It runs on psn Or by itself in large scale
you also don’t list how many endpoints
There are 20k endpoints, which is why I am concerned. We have 6x VMMs that we can use, and I want to maximize scale within that constraint. Does this help?
