12-13-2018 11:26 AM - edited 12-13-2018 05:24 PM
What scale or performance increases can we get if we break out MnT on its own? If we have VMM for PAN+PxGrid, MnT, PSN (RADIUS, TACACS+). Is this any better then combining PAN+PxGrid+MnT? This would all be ISE 2.4
Another question, if we are only doing 2 PxGrid connections does this still reduce the scale of the over all system? Is it better to have this standalone?
12-14-2018 07:36 AM
The only benefits you get are more endpoints when you split out pan mnt either on their own or combined
12-14-2018 01:30 PM
There are 20k endpoints, which is why I am concerned. We have 6x VMMs that we can use, and I want to maximize scale within that constraint. Does this help?
