01-17-2019 08:37 AM
Hi team,
The deployment scale and limits e.g. small, medium, large - are these hard and fast rules to ensure TAC support?
My customer wants 2 x admin/mnt and 6 x PSN. This falls just outside of a 'medium' deployment.
If the deployment scale is right, they need to move to a 'large deployment', but then they can't use the SNS 3515 according to the rules (their deployment will only authc/authz 6000 endpoints, splitting PSN for geographical reasons).
If they run 2 x admin/mnt and 6 x PSN on 3515's, will they be supported by TAC?
Arron
01-17-2019 08:42 AM
In my experience, yes. these requirements are hard and fast. I have multiple cases documented where minimum/recommended requirements were used as a 'potential' reason for my issue. To the point where I completely re-installed my deployment because of the headache, and also ISE VMs don't play well with hardware expansion.
01-17-2019 11:37 AM
I don't even think you will be able to join the 6th PSN to the deployment. I am pretty sure last time of customer of mine tried that it wouldn't let them. I would also challenge the need for so many PSNs assuming their network is properly build with correct redundancy, but that is another discussion.
01-17-2019 09:55 PM
I gave it a try because I have long wondered if ISE has any internal check for this. So I'm now able to bring some reliable information on this subject. The disclaimer obviously still stands, it's not tested, TAC will probably tell you that you have to change it, but you can certainly register six psn's in a hybrid 2.4 deployment.
01-18-2019 03:16 AM
Thank you - this is helpful.
Looks like the BU need to be made aware of this - there is a gap between medium and large deployment which quite a few customers actually fit into.
01-18-2019 03:51 AM
Agree. the requirements should be made more granular. What got us was disk space. We built it to spec based on some math surrounding endpoints, connections, log retention etc... but in the end could not get reliable support since our admin/mnt nodes did not have the recommended 600GB disk. Since these disks must be thick-provisioned, this had to be a re-deploy.
01-18-2019 03:58 AM
01-18-2019 05:35 AM
