ISE distributed deployment upgrade - 1.3 to 2.1
dot1x
Level 3
Level 3
My customer has an ISE deployment with 5 nodes: Admin/Monitor Primary and Secondary plus 3 Policy Server. The Admin Nodes and 2 Policty Nodes are VMs. The last Policy node is 3415 appliance.
I checked the release notes, it says that we can directly upgrade from 1.3 to 2.1.
Could someone share their experience or a step-by-step document to upgrade this distributed environment ISE deployment?
Thanks.
paul
Level 10
Level 10
As I have posted previously, I would recommend not using any of the Cisco documented GUI/CLI methods for upgrading.  The method I have found to work the best over the years is:
  1. Kick out secondary admin node from the old deployment.
  2. Fresh build it to the desired version
  3. Restore data from old version
  4. Verify restored data.  This node now becomes the anchor point of the new version deployment.
  5. One at a time rebuild each PSN by installing a fresh build of the new version
  6. Join the PSNs to the new deployment
  7. Finally rebuild what was the primary admin node of the old deployment and join it to the new deployment
  8. Move personas around as needed
7 Replies 7
paul
Level 10
Level 10
Agree with paul!
Thanks Paul.
What happens to the license when we use this approach?
Would it retain the licenses?
It won’t retain the license. You just need to rehost the licenses. I usually must email licensing@cisco.com<mailto:licensing@cisco.com>. They are very responsive.
My experience is the device ID doesn’t change if you are using the same VM so you should be able to reuse the same license files if you still have them. Otherwise, rehosting certainly works.
George
I'm fairly new to this, could you pelase have a look and advise if my understanding is correct?
Manually de-register Secondary Admin Node and take back up of this secondary admin node?
Using this?
https://www.cisco.com/c/en/us/td/docs/security/ise/2-1/install_guide/b_ise_InstallationGuide21/b_ise_InstallationGuide21_chapter_010.html#task_C60EBD3F53714C7BA83DC2E691E4FC1B
Restoring the back up taken in Step 1 for Secondary Admin Node?
At this point of time, do I de-register old PSNs one by one?
Should I take backup of Primary Admin node and then restore to new deployment? At this point of time, this will become secondary admin node in new deployment?
