07-23-2019 03:33 AM - edited 07-23-2019 03:33 AM
I am looking to replace the Certificate that is assigned to the EAP Authentication Role - However the question has come up:
Can this be a Public Certificate such as one signed by GoDaddy or does it need to be signed by the same CA that our Users get their Certificates from which is an internal Microsoft CA?
Solved! Go to Solution.
07-23-2019 04:42 AM
07-23-2019 04:42 AM
07-24-2019 01:47 AM
Thank you - So we can use an external CA Certificate for EAP Authentication Role on ISE whislt the clients use our internal PKI for EAP-TLS Authentication.
07-24-2019 02:21 AM
07-24-2019 02:23 AM
Thank you for confirming - I was finding conflicting information. I will be making this change once back from vacation.
