ISE External Captive Portal
rshehov
Does ISE support web authentication to an external captive portal?
Many thanks
Ross
Jason Kunst
There is no native support for this. You can perhaps do with advanced customization and use the Guest APIs.
7 Replies 7
Jason Kunst
Do you think is possible to achieve click-through in terms of external captive portal ?
Possiblly? Its not something we have integrated from the ISE team but there are partners that have done it. You will need to design and evaluate the flow and customization on your own as its not something we directly support.
Hi Jason,
Do you know the steps to apply my own designed customized portal into ISE?
All supported customization options are under http://cs.co/ise-guest
https://community.cisco.com/t5/security-documents/ise-guest-amp-web-authentication/ta-p/3657224#toc-hId-709188714
There are no external portal hosting supported configurations.
Hi Jason,
Thank you so much for the link. I'm almost getting there. ^^
Perhaps, is there virtual ISE LAP that I can try implementing it? For testing purpose without implementing
on our server? We had the ISE evaluation before but we removed it along with the entire network equipment which came with (Meraki) due to incomplete ISE captive portal build for our own.
Secondly, the link that you provided has the information about ISE Guest SMS Support, and only mentioned about user getting user ID and Password via SMS text message and non about OTP.
My final goal is implementing "sending OTP code to the user via SMS" and no user ID and password for the ID creation via SMS
Please help.. Thank you so much.
I'd suggest opening separate thread about new issues questions so we can better coordinate.
