Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
395
Beginner
ISE guest portal customization
Hi everyone,
I am trying to create the guest policy on ISE. I only want to use password field which changes 1st day every of month which users can access on the company's website. Is there a way we can create that? No username, only password.
If there is a way then i have another question only if its possible. Is there a way to create a script or auto generating policy that changes the password every month and it sends an automatic email to the company's website to update it? Or do i have to make an external radius linux box and create a script that does it every month?
Any help would be really appreciated. And I am running ISE version 2.2
Everyone's tags (3)
1 ACCEPTED SOLUTION
Highlighted
Re: ISE guest portal customization
To keep it simple for yourself why not use the hotspot portal with its passcode option
You will need to create your own scripting but here is something to get started
https://communities.cisco.com/docs/DOC-64018?mobileredirect=true#jive_content_id_Customizations
Look at the ISE api automating hotspot link
2 REPLIES 2
Highlighted
Highlighted
Beginner
Thanks for your help Jason
