ISE Guest portal FQDN pointing to 2 IP Address
janvelgado_16
Have anyone tried setting up a guest portal FQDN mapped into two different IP address in which these two IP address corresponds to the IP address of PSN nodes?
Let's say for example
PSN1: 1.1.1.1
HOSTNAME: psn1ise.company.com
PSN2: 1.1.1.2
HOSTNAME: psn2ise.company.com
Guest portal uses fqdn:port policy
ex. FQDN: guest.company.com
nslookup guest.company.com shows both the IP address of PSN 1 and PSN 2.
same guest cert installed on both psn1 and psn2.
I have found this guide https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/117620-configure-ISE-00.html but it will need new cert, new fqdn and additional alias.
Hoping to hear from you ISE masters. Thank you.
JAN
Jason Kunst
Correct that’s the way you do it. Yes you will need to change cert so the client trusts it.
Jason Kunst
How would this work if the client is redirected to the guest portal.cwa, As the client https request needs to land on the same psn the radius request landed on.? How would you hide the psn fqdn in the redirect url?
You can’t hide the host it’s communicating to. Would recommend a certificate with a wildcard in the San
More information available under admin guide for certificates
https://www.cisco.com/c/en/us/td/docs/security/ise/2-2/admin_guide/b_ise_admin_guide_22/b_ise_admin_guide_22_chapter_0110.html#concept_8B6D9760C14344EC972B2DD81876328B
If you do not want to re issue certificates and you have spare public ip addresses you can also nat 1:1 the ise guest ip addresses and let dns doctoring do the trick.
You need however to register an A record for each ise on your public dns server.
It also works registering A records on your public dns server pointing to the real (internal) ip addresses of ise guest interfaces, this permits you to save public addresses.
This way, however, securitywise guys could argue that you are disclosing internal resources.
