Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
129
ISE Guest Portal Question
Hi Team,
I would like to check if ISE guest portal supports the following:
  1. At the guest WIFI portal, customer looking at a text box to enter sponsor name.Once the sponsor’s name is partially typed, the text box will populate "possible" sponsor's name and auto fill into the text box. The "possible" sponsor's names are retrieved from AD.
  1. Once sponsor's name is in the text box, together with guest's particulars, ISE need to send email and SMS to sponsor with the guest username and password.
Note: guest only keys in the sponsor's name. ISE will need to extract the sponsor's email and phone number from AD. After that, ISE is required to send the guest username and password to sponsor's email and handphone number.
Hope to hear from you soon.
Thanks!
1 ACCEPTED SOLUTION
Highlighted
Re: ISE Guest Portal Question
@Colby.LeMaire wrote:
That is not how the guest portal works by default.  You enter the sponsor's e-mail address and then ISE sends the e-mail there for approval.  It may be possible to use JavaScript on the guest portal to do something but I doubt it would be able to connect to AD and pull information on the fly like that.
Correct. This is not something the product does. This is something that has been asked. Its not something you can code the product to do currently as it requires cross-site scripting which is blocked. Also the other ask for you to send email to sponsor can be done by changing the guest email to that of the sponsor, something you could do on the page with javascript
perhaps if you don't have alot of sponsors you can make your own list, see the option under the http://cs.co/ise-guest page
https://community.cisco.com/t5/security-documents/ise-guest-amp-web-authentication/ta-p/3657224#toc-hId-1218178370
To contact our product team for future enhancement requests, externally for cisco customers/partners at http://cs.co/ise-feedback for cisco employees internally at http://cs.co/ise-pm
2 REPLIES 2
Highlighted
Rising star
Highlighted
