Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
117
Highlighted
ISE guest portal
Hi there,
Can the ISE guest portal be customised to redirect to the external registration server?
Thank you so much.
Ross Shehov
Everyone's tags (5)
1 ACCEPTED SOLUTION
Re: ISE guest portal
Ross,
URL Redirection can be used to redirect to any URL you want with ISE.
If you have an external server doing the Guest registration you may redirect them there.
I assume you are then using our REST-based Guest APis to have this external server configure the Guest account in ISE.
2 REPLIES 2
Can you explain the flow? We don't integrate with external registration servers, this would be advanced customization
Ross,
