ISE guest portal
rshehov
Hi there,
Can the ISE guest portal be customised to redirect to the external registration server?
Thank you so much.
Ross Shehov
thomas
Ross,
URL Redirection can be used to redirect to any URL you want with ISE.
If you have an external server doing the Guest registration you may redirect them there.
I assume you are then using our REST-based Guest APis to have this external server configure the Guest account in ISE.
Jason Kunst
Can you explain the flow? We don't integrate with external registration servers, this would be advanced customization
thomas
Ross,
