ISE Guest Portals features and maximums
gugonza2
Hi Team,
Checking the Guest Management solution in ISE, a customer has some questions:
Is there any limits for Guest Portals and Guest users per portal ?
What is the maximum number of Guest Portals we can define using ISE 2.4 or 2.6 ?
In each Guest Portal, how many Guest Users we can manage per portal ?
Using Guest Portals, we can use or apply CoA for actions with Guest Accounts ?
Is there Device Limits per Guest Users ?
Thanks in advanced.
Jason Kunst
@gugonza2 wrote:
Hi Team,
https://community.cisco.com/t5/security-documents/ise-performance-amp-scale/ta-p/3642148
there is no such limit of guests per portal, its for the whole system
see above
see above
need more info but generally yes
this is configurable per the admin guide
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_01111.html#concept_921E58BE513A4E6EABEEDF380391A7A3
Thanks in advanced.
ldanny
Thx Idanny for the reference.
But, I don't see the maximums numbers about Guests Portals or Guests users per portal.  Is there any limit for that ?
Jason Kunst
@gugonza2 wrote:
Hi Team,
see above
see above
Thanks in advanced.
Thx a lot Jason.
