Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
122
Highlighted
Beginner
ISE integration Oracle OUD
Good afternoon!
I am working with a customer that requested to integrate ISE wit Oracle OUD (LDAP) is it posible? Is there any particularities to this integration?
Another point that they have questioned us, they want to do compliance over a Checkpoint VPN, is that posible? Is there any restriction?
Thank you!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: ISE integration Oracle OUD
Hi Vitor,
Please check the compatibility guide per release as to what it is validated with.
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/compatibility/b_ise_sdt_24.html#externalidstores
We validated with Sun ONE and Open LDAP.
That does not mean it may not work with others,it would work with standard LDAP protocol and needs to be tested with it.
As for Checkpoint VPN, here is a guide and some notes from support forums. ACS is very similar to ISE is a forerunner to ISE.
https://supportcenter.checkpoint.com/supportcenter/portal?eventSubmit_doGoviewsolutiondetails=&solutionid=sk98733
https://cisco-marketing.hosted.jivesoftware.com/message/290010
https://supportforums.cisco.com/t5/aaa-identity-and-nac/cisco-ise-integration-with-third-party-firewalls/td-p/2343416
How to configure Remote Access authentication against Cisco ISE
Hope it helps.
Krishnan
1 REPLY 1
Hi Vitor,
Hope it helps.
Krishnan
