ISE 2.6 Patch 1 is available! View the ISE 2.6 Release Notes and Download the Patch!
ISE 2.2 Patch 14 is available! View the ISE 2.2 Release Notes and Download the Patch!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
433
Highlighted
Beginner
ISE integration with Azure AD
Hi all!
I have multiple problems using 802.1x authentication in my environment. Wu currently use cisco wlc -> MS NPS -> Azure AD
We're looking for possibility to replace NPS with brand new Cisco ISE.
Is it possible to use Azure AD as external identity source for 802.1x?
Probably someone could provide guide how to configure such interaction.
Everyone's tags (4)
1 REPLY 1
VIP Advisor
Re: ISE integration with Azure AD
Yes, this possible. From ISE, you are can Azure AD by joining ISE to domain
or adding it as LDAP server. Both ways you can get the integration working
(there are limitation if you use it as LDAP). To join ISE to domain, you
need to configure ISE with domain DNS servers to resolve the domain to
azure AD.
