ISE integration with Third Party Proxy
ecanogut
Hello all,
One of my customer wants to integrate ISE with a Fortinet proxy so that when a user (already authenticated on ISE) wants to navigate on internet the proxy does not prompt for user's credentials.
My understanding is ISE should send authorization session to the proxy to achieve this.
Does any one has done something similar to this?.
Thanks in advanced.
Timothy Abbott
This functionality is already supported by Cisco WSA.  The WSA uses pxGrid to fetch SGT information for the end user accessing the internet.  Fortinet would need to build a pxGrid client into their solution to download identity information from ISE.
-Tim
6 Replies 6
Timothy Abbott
-Tim
Jason Kunst
please see several other posts on the issue with ISE sending RADIUS to Fortinet
https://communities.cisco.com/search.jspa?q=ise+fortinet
ecanogut
So, my question is: Can fortinet be integrated with ISE using PxGrid?
Have you asked fortinet if they have a PXGrid client in any of their firewalls?
Warning: I either dictated this to my device, or typed it with my thumbs. Erroneous words are a feature, not a typo.
No, you will need to ask them to reach out and start the process
https://www.cisco.com/c/en/us/products/security/pxgrid.html
Thank you all for your answers, will inform the customer about it.
